How does keep track of changes to the data work? How can we view historic data
9256
10
07-16-2024 06:46 AM
LyonMNGIS
Hello,
I have a couple questions regarding the option in AGOL to keep track of changes to the data field (add, update, delete features).
  1. Is the purpose of this function to archive changes to any AGOL hosted feature layers?
  2. Can we view any changes (including deletions) in ArcGIS Pro?
  3. I noticed I cannot turn keep track of changes to the data on or off in the settings menu.  This is true even if I turn editing off.  Why is that and how can I turn keep track of changes off?
  4. Is there anything else I need to know about this function?
Thank You!
ChristopherCounsell
MVP Frequent Contributor
No. It tracks the change event only. It's basically a giant table of time + note if an add, update or delete was made.
It's useful for monitoring change events. E.g. fire a webhook response when a feature is edited in field maps.
Not the changes, just if a change happened. And not really in Pro, more via REST API or ArcGIS Online which you could move to pro.
Best guess is it's a view, you need to disable on parent layer. Otherwise maybe read through the documentation above.
What you're looking for is called versioning and it requires an enterprise geodatabase / ArcGIS Server. In ArcGIS Online your tracking options are more limited. General recommendations are regular data backups offline (you could use an enterprise geodatabase here to version change), or the use of related tables for 'adds only' against existing records.
Koen
by Esri Contributor
Hey @LyonMNGIS
I was able to find documentation:
  • Also, if you publish a hosted tile layer from the hosted feature layer, and the hosted tile layer is configured to build tiles automatically, you cannot disable the Keep track of changes to the data (add, update, delete features) option on the hosted feature layer.
  • The Keep track of changes to the data (add, update, delete features) option allows custom applications to identify which features have been added, updated, or deleted. This setting is enabled automatically when you publish a tile layer from the hosted feature layer, because it is necessary to keep the two layers in sync.
Hope this helps! Feel free to reply to this thread with any additional questions.
- Koen
Koen
by Esri Contributor
Additional section in that article
  • Hosted feature layer views inherit this setting from the hosted feature layer from which they are created and cannot be configured independently. To enable or disable editor tracking for a hosted feature layer view, change the editor tracking setting on the hosted feature layer from which the view was created.
ChristopherCounsell
ChristopherCounsell
Hot off the ESRI UC I was wrong about change logs, apparently you can recover it as JSON. Explains why the logs get so large.
Have to use rest API.
mdibbinsSNO
Hi @ChristopherCounsell,
Would you happen to know if this deck was published anywhere?
JanetSilb_Spike
@ChristopherCounsell can you please explain how to do this in the new AGOL release: "more via REST API or ArcGIS Online"?  I've been trying to follow a process guided by ChatGPT but I think it may be outdated.
Janet Silbernagel, PhD, ASLA, SITES AP, WBE
Silvernail Studio for Geodesign, LLC
https://www.linkedin.com/in/jsilb/
Bud
Legendary Contributor
@ChristopherCounsell  Your original reply was helpful. Thanks.
Here’s a related article: Added, Updated or Deleted? Track changes to your data in ArcGIS Online
MaximilianLWaechter
Hey Christopher, I was running into similar issues but with viewing the table of events. I've made several changes to a hosted layer, saved it. Then attempted to view the change log, and nothing appears. Is the change log not viewable in ArcGIS online? Currently I wanna start with the capability of seeing when someone makes any type of change and keeping track of that, with later capabilities of starting a server and keeping track of what changes were made more specifically.
ChristopherCounsell
Can you confirm are you talking changes to the layer or edits? Change
tracking applied to feature edits
