How do I upload a CSV file as a feature layer with images (JPG or PNG) attached to each data point?
948
11-29-2019 12:53 AM
WordsworthTrust
I have been able to create feature layers with all my sets of data for a public map. However, I have images associated with each data point so the public can select a data point on the map and view a picture of the place. Is there a way I can upload the data all at once? I haven't yet found a way to have the images there as well. I am hoping I will be able to find a way that I can upload all 50 images at once with all of my data points, rather than manually entering in each image.
Egge-Jan_Pollé
Hi Wordsworth Trust‌,
Using ArcMap, you could create a Feature Class from your CSV and enable attachments for this Feature Class. In this way you can attach your images and publish your data to a Feature Layer (with images attached), all from within ArcMap.
HTH,
Egge-Jan
