How do I create a ArcGIS Server geocode service tool using my own GeoCoder?
1895
04-10-2013 09:30 AM
ChrisCorwin
So I created a geocoder service that uses our county's own data, no NAVTEQ errors this way. I use it in my Flex Application webpage. But I want to add it to my web map so my responders can use it while using the ESRI app. So, I was hoping there was a way I could add it to my web map. I looked through the help and got lost. So it might be there, someone pointing me in the right direction would be greatly appreciated.
Thanks!
Chris
MattSimmons
From the sounds of it, you have a geocoding service already, which you probably have in ArcSDE.  You need to publish this to ArcGIS Server first, and then you can configure your web map to consume the geocoding service.  Try here:
http://resources.arcgis.com/en/help/main/10.1/index.html#//002500000036000000
ChrisCorwin
That is what I want to do, Configure my ArcGISonline.com web map to consume my geocode service.
I just do not see where to do that on ArcGISonline.
divyamgulati1
As of now there is no way to use your own geocode service for your Arcgis online hosted web maps..
What you can do is download the web application template. Add your web map and make necessary changes to include your own geocode service. You can then host this application on your web server.
baileyhanson
Are steps basically the same for a batch geocoding service?
