Can you publish Map Services in ArcGis Online
784
12-15-2013 05:50 AM
ScottDawson
I have a few fairly large complex applications that are currently using map services hosted on an inhouse ArcGis 10.1 server.  The CIO office would like to move toward ArcGis Online hosting.  Can a user publish a map to Arcgis online and have it be served as a map service (ie... so I can create DynamicMapServiceLayer),  rather than dealing with either a Web Map?
I'm trying to get a handle on the scope of the modifications that will be needed. As a web Map is not quite the same as a Map made up of various DynamicServiceLayers on a basemap.
I hope this makes sense.
Thanks.
RichardWatson
No, you cannot.  The only map services which can be hosted in ArcGIS Online (AGOL) are tiled map services which simply serve static images.
USFS_AGOLAdministrator
What about feature services?
RichardWatson
