How can I customize the scale when embedding in website
1049
02-28-2013 11:45 AM
ErikFernandez
The arcgis online scale +/- is pretty crude in that each level of zoom is a huge difference. Is there anyway to easily customize the scale to find a middle mark between to zoom levels? End goal being to embed the html code in our website. Thanks for any tips, especially ones that don't require writing code.
Erik
MikeMinami
Esri Notable Contributor
The scale intervals are directly tied to the basemap in the web map. If you are using ArcGIS Online default basemaps, then you can't change the scale intervals because the basemaps are tiled, meaning they are pre-created images for a given scale. They are not dynamically generated. If you have your own basemap, based on an ArcGIS Server service that is dynamic, then you won't see the scale intervals at all and will just have the + and - options. Alternatively if you have your own tiled map service, the intervals will be base on your tiling scheme.
Hope this helps.
Mike
