Hosted layer responding very slowly
1577
08-15-2024 04:56 AM
KenBouchard
I have a hosted layer that respond very slowly.  Any edits I try to do on it, on a webmap, takes over 10 seconds.
If I click on the "View URL" from the ArcGIS Online overview page, it takes forever to load the page, way more than any of my other layers.
I don't think I can republish the layer as it's the source layer for a public S123 form.  I don't want it to modify the URL link to access the form.
I've tried rebuilding the indexes, didn't change anything...
Any idea somebody?
Ken
MichaelVolz
Esteemed Contributor
Any connection here:
https://community.esri.com/t5/arcgis-pro-questions/append-tool-not-working/m-p/1521888#M87007
INC-001547: Asynchronous operations are slow to complete on all service endpoints.
MichaelVolz
AGOL Health Dashboard
https://status.arcgis.com/
David_McRitchie
Hey Ken,
It might be worth checking the datastore input and output. You can do this if you are an Organization administrator by navigating to the Organization tab > Overview and selecting the Feature Datastore hyperlink. The following blog shows what this will look like.
If you are seeing certain times that things are slow (like first thing in the day...right after lunch when everyone logs back in) then it could be a sign that the datastore is struggling.
I would also check to see if you have sync enabled. This can add a lot of tables on the backend which could cause a slowdown if the layer has been up for a while and frequently edited.
Hope that helps,
David
Esri UK -Technical Support Analyst
