Hosted Layer not showing attributes when clicking feature
1054
09-15-2023 08:48 AM
GregZartman
I have a hosted layer, one of many, in AGOL with attributes.  When I click on a feature, the dialog doesn't show me any of the attributes for the feature in this hosted layer.  However, with other hosted layers if I click a feature in a layer it brings up the attributes for that feature.  The only way to see the attributes is to select "Edit".
Is there a setting someplace that I need to select to show the attributes when I select a feature?
KenBuja
Have you enabled the popup for that layer?
KenBuja
GregZartman
That did the trick, thank you!
