Host map services from ArcGIS Server to ArcGIS Online
5039
03-06-2015 04:35 AM
DhowalDalal
We currently have a host of map services on our ArcGIS Server . These are all added on ArcGIS Online. We now want to host all the map services on ArcGIS online. what is the best way to migrate these without having to re-do all our webmaps? Thanks.
JakeSkinner
Esri Esteemed Contributor
Hi Dhowal,
Take a look at the ArcGIS Online Assistant.  This will allow you to update the data sources of your web maps.
JakeSkinner
Hi Dhowal,
DhowalDalal
Thanks Jake ...
NeillJobe
Admin Tools for ArcGIS Online & Portal will do all of this for you without all the work.
LeoLadefian4
You'll have to republish the services in Arcgis Online first, then update the sources with AGOL assistant.
