Hi there, I have a arcade expression to try to update FC from another one on the same webmap, so I get a error in the line three. help to correct this
1075
08-25-2023 06:10 AM
JoseVeiga
var featureToUpdate = FeatureSetByName($map, "Area Lote", ["refcadastro", "estado"]);
var featureToCopyFrom = FeatureSetByName($map, "edicao_visualização", ["refcadastro", "estado"]);
var FeatureSetIntersects = Intersects(featureToUpdate, Buffer(featureToCopyFrom, 5, "meters"));
var matchingFeature = First(FeatureSetIntersects);
var UpdateFeature = FeatureSetByName($map, "Area Lote");
if (matchingFeature) {
var updatedValue = matchingFeature["refcadastro"];
return UpdateFeature(matchingFeature, {"estado": updatedValue});
return null;
KenBuja
MVP Esteemed Contributor
Two things that cause a problem.
Buffer takes a feature, not a feature set.
Intersects takes a single feature as the second input.
