Help with Rule Attribution in Arcade
2429
06-22-2021 09:32 AM
Labels (3)
ChrisGAEG
I'm trying to write an Arcade expression that does the following. If a line is within the boundary of another poly layer, the line takes the name attribution from the boundary, but only if the line is of a certain type. So far we have this which does the first part.
var OLT = FeatureSetByName($datastore, "Proposed_OLT_LCP_Boundaries",["cab_id"], true)
var intersectLayer = Intersects(OLT, Geometry($feature))
if (Count(intersectLayer) > 0) {
    var layer = First(intersectLayer);
    return layer.cab_id;
} else {
    return null;
However I'm struggling with the part that only pulls in cab_id if intersectsLayer is of a certain type. Any input on this is greatly appreciated.
DavidPike
MVP Notable Contributor
if (Count(intersectLayer) > 0 && ($feature.cabletype == 'F1' || $feature.cabletype == 'F2')) {
} else {
    return null;
DavidPike
A certain type? can you elaborate?
ChrisGAEG
Yes we have a type field that has different labels. And we only want this function to apply to lines of a specific type in the layer. Here's what I'm trying to do (Although incorrect so far...)
if ((Count(intersectLayer) > 0) and ($feature.cabletype == 'F1' or 'F2')) {
    var layer = First(instersectLayer);
} else {
    return null;
DavidPike
} else {
    return null;
ChrisGAEG
That works! The syntax example will also help a lot for future rules, so thanks so much!
