Help with a web map idea
716
11-04-2024 10:00 AM
BrianBulla
Honored Contributor
So I am a member of a provincial association (not GIS related) and I'd like to create a map that we can use to show members locations, so we can better connect.  I need it to be freely available without asking people to create an account on AGOL.  Is this something I can even do with AGOL??  I rarely use AGOL.
Basically I think I'd like the user to enter an address or location and put a pin on the map, with some information of their choosing.  I don't need 100% accurate placement....most people probably wouldn't want that....just an approximate location.
And with some basic 'branding' so that people know what the map is for.
Thanks!
TonyContreras_Frisco_TX
Survey123 will probably meet your needs. It may be up to the user to place the location in a non-specific spot like an intersection or commercial area. You can set up surveys that are shared with everyone, but that will require the feature service that stores the data to also be shared with 'everyone' (an ArcGIS Online term). This will need to be planned and set up carefully, following the tips in this blog post.
