Hi, is the heat map symbology option supposed to look like this? With that horizontal banding? I have a dedicated graphics card so I'm not sure what's going on here. Heat map symbology looks fine in Pro. I use Firefox. If anyone has a solution let me know because I can't publish a map that may render like this for users.
Can you share the web map? thanks!
Sure, here's a copy: https://maps.arcgis.com/apps/mapviewer/index.html?webmap=08a813767b4a4152be635c2c47deff72
I just opened in Chrome with the same issue.
Do you have the versions you are using. I cannot see this on FF or Chrome using latest builds. Also might need some info on what your graphics card is.
Sure, I'm using latest versions as well (firefox 110.0.1, chrome 110.0.5481.178)
Graphics card is a Radeon Pro WX7100, driver version 31.0.12016.9
I tested on my M2 Mac and it does render properly there.
I recommend logging a support ticket. I think this might be graphics card related. I cannot reproduce this on other tested machines and browsers.
I think I'd rather just use different symbology. Thanks.
