Heat map render issues
2414
7
03-08-2023 12:06 PM
wayfaringrob
Honored Contributor
Hi, is the heat map symbology option supposed to look like this? With that horizontal banding? I have a dedicated graphics card so I'm not sure what's going on here. Heat map symbology looks fine in Pro. I use Firefox. If anyone has a solution let me know because I can't publish a map that may render like this for users.
RussRoberts
Esri Notable Contributor
Can you share the web map? thanks!
wayfaringrob
Honored Contributor
Sure, here's a copy: https://maps.arcgis.com/apps/mapviewer/index.html?webmap=08a813767b4a4152be635c2c47deff72
I just opened in Chrome with the same issue.
RussRoberts
Do you have the versions you are using. I cannot see this on FF or Chrome using latest builds.  Also might need some info on what your graphics card is.
wayfaringrob
Honored Contributor
Sure, I'm using latest versions as well (firefox 110.0.1, chrome 110.0.5481.178)
Graphics card is a Radeon Pro WX7100, driver version 31.0.12016.9
wayfaringrob
Honored Contributor
I tested on my M2 Mac and it does render properly there.
RussRoberts
I recommend logging a support ticket. I think this might be graphics card related. I cannot reproduce this on other tested machines and browsers.
wayfaringrob
Honored Contributor
I think I'd rather just use different symbology. Thanks.
