Has Anyone Tried Setting Up Collaboration Between AGOL & Portal?
1643
09-12-2018 07:50 AM
by Anonymous User
Not applicable
Please share your experiences implementing Collaboration between your AGOL and on-premise Portal.
  • Any challenges setting it up and getting it working?
  • Any things that you like or that surprised you?
Our Enterprise GIS team is interested in setting up Collaboration, but given our past experiences getting new ESRI products or features up and running seamlessly, we have our hesitations that it will work out as easy as it was demo'd at the ESRI UC or that it could be as simple as checking a box. Since once Collaboration is setup it cannot be undone, we therefore would appreciate hearing from the community on their experiences getting Collaboration up and running.
deleted-user-8KkqhMYcTNGx
Skyler DeweyBrandon LongenbergerJohn Reese‌ We have begun looking into this also, and have had our hesitations as well. Currently we set up a test collaboration between our enterprise portal and our ArcGIS Online Organization. It is a one way distributed collaboration and it is using the As copies setting. We found this help page that answered our questions pertaining to schema changes.  We performed the following test and it worked:
  • We had a hosted feature layer in our ArcGIS Enterprise Portal
  • Then we added a field (it should be noted that the field did not show up after synchronize at this time, because it will not per the documentation)
  • Then we unshared the hosted feature layer from the collaboration group
  • Then we synchronized the collaboration
  • Then we reshared the hosted feature layer to the collaboration group
  • Then we synchronized the collaboration again
  • The result was our new field showing up in the feature layer in our ArcGIS Online Organization.
We want to test further to see if the middle synchronize of the collaboration needs to happen, and we also have future testing planned to see if this workflow will accommodate data from SDE GDBs.  Let's keep sharing our adventures so we can figure this our together. Thank you for everything and have a delightful day.
Sincerely,
Joe Guzi and Skyler Dewey Brandon Longenberger John Reese
