GPS zooms to close when on a mobile device.
3994
03-03-2016 06:33 AM
WesMiller
I've created a web map that has some simple features in it. When using the map on a mobile device you can click the target symbol so the on board gps will locate you on the map. The problem i'm having is that when you are located, the scale level is so small that you can't where you are is there a way to set the zoom to scale for the gps locator?
WesMiller
Anybody know where a setting might be to fix this?
MatthewKing
If you're using Web AppBuilder I noticed in the location widget setting there's an option to set the zoom scale.
