GPS meta fields
454
05-28-2026 07:06 AM
fjramos
Good morning,
Is there a way to manually add GPS meta fields to an already existing hosted feature layer? Thanks
JonathanLebowitz
You would need to run the Add GPS Metadata Fields geoprocessing tool on the source data and then overwrite the hosted feature layer.
VenkataKondepati
Honored Contributor
Hi @fjramos,
Yes. It depends on the type of GPS metadata fields.
You can refer to Prepare for high-accuracy data collection—ArcGIS Field Maps | Documentation
field-maps-scripts/notebooks/Add GPS Metadata Fields_FS.ipynb at main · Esri/field-maps-scripts
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
JonathanLebowitz
