Georeferencing error 00037
2594
12-29-2020 12:55 PM
by Anonymous User
Not applicable
I am trying to take a map from a PDF document and get it so I can use it in ArcGIS Online. I was following a great tutorial but ran into a snag.
My overall methodology is to georeference the pdf map (that I converted into a JPG before putting it into ArcMap Desktop) and then I get it the way I want it. After I georeference the JPG image I rectify and delete the base map I was using. Now I go to share as a service ---> publish a service --> choose a connection ---> and then I fill out the service editor. HOWEVER, once I click analyze I get this error:
Severity: High
Status: Unresolved
Code: 00037
Description: Basemap Layers cannot be published directly to a service
Type: Payer
Data Frame: Layers
I don't know why I am getting this error! I UPLOADED AN IMAGE SO YOU CAN SEE MY SCREEN, JUST DOWNLOAD THE IMAGE. Any advice?
I'm trying to follow this guys tutorials: https://www.youtube.com/watch?v=aXu6xdIzzIY&t=1s
https://www.youtube.com/watch?v=klFwpWTUi8A&index=23&list=UUdShBEYmIgoDn34bi1vVA9w
DavidPike
MVP Notable Contributor
Can you post a screenshot, but showing the 'List by Drawing Order' option in ArcMap. Using the table of contents—Help | ArcGIS for Desktop
Can you also show sshots of all the options in your publishing wizard if able.
by Anonymous User
Not applicable
Thank you for your reply! I'm not sure how that helps get a PDF map onto a map I'm making in ArcMap online.
DavidPike
Of course, good luck.
