GeoForms
1695
10-23-2018 07:40 AM
Jose_LuisGarcinuno-Oporto
Is there a way to edit the information added through a GeoForm, like:
Select the point
Delete or Update the info related to the point (tabular data and location)?.
Thanks!!
by Anonymous User
Not applicable
The GeoForm application template is not designed to be used as a client for editing existing features.
Are you hoping to have end users edit existing features? If you might want to explore some of our applications for general editing.
Choose a configurable app—ArcGIS Online Help | ArcGIS
KellyGerrow
Esri Alum
Check out crowdsource manager for managing existing data:
Crowdsource Manager | ArcGIS Solutions for Local Government
-Kelly
BrianBaldwin
It really depends on the workflow. If you are looking for a QA/QC process to clean up the data, you could easily put the GeoForm feature layer into a Web App Builder application with the Smart Editor widget. This would provide a really simple, light weight application for a user to review and edit only certain aspects of the data that you want changed.
Brian Baldwin, Esri Inc., Lead Solution Engineer
https://www.linkedin.com/in/baldwinbrian
