geocoding on csv load does not show error records
1230
07-27-2012 08:39 AM
ClemHenriksen
hi,
i load a csv with address info. 58 records. load goes well, except i get this message
[ATTACH=CONFIG]16441[/ATTACH]
how can i find out which 2 records are in error?
AnnaFischer1
I don't believe there is currently a way to know which entries are causing the errors, aside from the tedious process of uploading each entry separately.  If you have ArcGIS desktop, you can geocode in desktop and then publish the map or upload the shapefile to ArcGIS online.
