from arcgis.mapping import export_map
727
01-24-2019 02:23 AM
GhazalBa_khadher
I want to export my map using this function to different fromat
but I do not know how to use it, if anyone has example or tutorial to use this in order to export the map to pdf format or picture , I would be happy
DanPatterson_Retired
beyond what is in the api reference?
arcgis.mapping module — arcgis 1.5.2 documentation
export_map
the parameters are specified
mapping.export_map(format: str = 'PDF', layout_template: str = 'MAP_ONLY', gis=None)
so you would specify …  export_map('PDF', 'MAP_ONLY', None)  … or whatever parameters you want
