Flashing Dot When Item Selected - Dashboard
2285
6
09-05-2024 10:32 AM
FenHow
Hi, can someone tell me how to change the size and color of the “flashing dot” that appears when you make a selection from a selector in a Dashboard?
I have looked and found where I can modify the flash rate by editing the JSON file, but not the size and color.
Thank you so much,
Fen
jcarlson
The color is in the dashboard theme settings:
The size, I don't think you can control without doing something really hacky, like buffering the point feature in a Data Expression or something.
- Josh Carlson
Kendall County GIS
FenHow
Thank you. In the past on other maps the flash was a round dot, now its a rectangle and small and is drivng me  nuts. I found the color change, that worked.
Thanks.
Fen
jcarlson
Weird, mine is still a dot. Are the features points, or polygons?
- Josh Carlson
Kendall County GIS
FenHow
Points.
GretchenFolse
I'm not seeing any options at all to edit Map colors in my Dashboard... is this something that may have moved or gotten phased out in a recent update?
(snapshot attached)
GretchenFolse
UPDATE: Found another way to do this just by changing the "Accent color" in the Custom theme settings (because that also seems to dictate the color of the flashing halo around the point when it's selected) and by poking around in the ArcGIS Online Assistant and making some edits in the JSON.
