Find objects without geometry
157
2 weeks ago
WaltherLie
I created a hosted feature layer with points, importing from an excel chart. Some of the points did not have latlon, so these are not showing on the map.
How can I find the lines in the data tab, that are not visible on the map? And how can I give them coordinates?
I have the X and Y column available, and tried to enter the values here, but it did not help. Is there any other way to do this?
jcarlson
I don't know a way of doing this through ArcGIS Online, but  ArcGIS Pro's field calculator can update the shape of a feature and assign coordinates to a point. Finding objects without geometry can probably be done with a select by expression like "SHAPE is null" or something.
- Josh Carlson
Kendall County GIS
WaltherLie
Thank You for Your reply. I haven't found out that to work so far. I update if I find an easy way.
