Filtering data to be published to a hosted Feature Service
744
06-12-2012 04:40 AM
MiguelParedes
Greetings All,
I have a huge data set. It covers all of the UK. I want to publish a relatively small area of the data set as a hosted feature service from ArcMap 10.1.  My data set is made of about five feature classes; point, line and polygon.  I would like to be able to set some sort of Clip capability (based on a shape, the Frame, etc.) so that when I use File > Share as Service...  only the data that is clipped is published as a feature service.  Is this possible, and if so, how would I go about doing it?
Many thanks in advance.
Miguel
MikeMinami
Esri Notable Contributor
I'd say you have to clip the data first before publishing using clip from the toolbox in desktop...
Mike
