Hello all, having trouble with something that seems as if it would be fairly simple, but it has escaped me completely.
I am trying to filter dates from a related table in a dashboard popups. I can set a filter in the map, however when I click on the item, the popup still shows all dates.
I am using an arcade expression inthe popup but my experience with arcade is limited and unsure if that is the culprit or not. (see working example below). Should I add the filter to the expression or is there something simpler I have overlooked? Attached a schema screen shot. Any help would be appreciated, thanks in advance.
var relRec = orderby(FeatureSetByRelationshipName($feature,"Collections"), "FinishTime DES");
var cnt = Count(relRec);
var relatedInfo = "";
if (cnt>0) { var info = First(relRec);
relatedInfo = Text(ToLocal(info.FinishTime),"MM/DD/Y");
} else relatedInfo="None To Date";
return relatedInfo;
