File Backups?
1721
01-04-2019 08:14 AM
KariLeer
Does ArcGIS Online have a file backup system? I am in need of an older version of a FGDB that was previously stored on AGOL. When I downloaded it, the attachments for a specific feature class did not fully download but I had already updated the FGDB online before I realized this. HELP!!
AdrianWelsh
MVP Honored Contributor
Kari,
I do not think this is possible.
There have been a few ArcGIS Ideas‌ requests out there for this but this still has not happened. You can vote up this main idea:
ArcGIS Online Back-ups - hosted feature layers and web maps/apps
DerekLaw
Esri Esteemed Contributor
Hi Kari,
Unfortunately, I think you've lost the previous "version" of your file geodatabase stored in ArcGIS Online. Sorry.
Please vote for the enhancement as Adrian Welsh suggested.
FYI, Back-up data in ArcGIS Online blog, for future reference.
Hope this helps,
AdamEversole1
Hi Kari,
I may be incorrect in my understanding because I'm not sure your are working with a service, but I'll add this note that if you have a Hosted Feature service, and you have not deleted the Service definition file, or overwritten that service, that .sd file can be downloaded and extracted as if it was a zip file, the original File Geodatabase and a map document are inside.
But yep, If this was a Standalone file geodatabase item that was overwritten/deleted then replaced, there is not a way to retrieve it.
