FieldMaps Label Issue with Aggregation
350
03-18-2026 07:42 AM
Jasper_Rasokat
Dear ESRI Community,
I am encountering what appears to be a labeling bug in the Field Maps app. When working with large point datasets, I enabled point aggregation.
Since then, label display becomes inconsistent whenever points have been aggregated during a session. After aggregation occurs and I zoom back in, many labels fail to reappear—even after waiting for an extended period.
I also tried limiting aggregation to a higher zoom level, but the issue persists. Without aggregation enabled, labeling works as expected.
Has anyone experienced similar behavior or found any documentation addressing this issue?
Thank you in advance.
Jasper
DanielFox1
Hi @Jasper_Rasokat
Thank you for raising this issue, from a search I believe that this is related to an enhancement which has been logged and also references another community post on this topic
https://community.esri.com/t5/arcgis-field-maps-questions/clustering-symbology-not-available-in-fiel...
At present the enhancement is in review, and I would encourage you to log a support case with your distributor so they can confirm and attach your case to the enhancement so you can updates on its life cycle.
DanielFox1
Hi @Jasper_Rasokat
