Field with multiple choices
1367
02-12-2024 11:14 PM
GISUSER8
Can domains with multiple choices be created in ArcGIS Pro ?
Or can lists with multiple choices in ArcGIS Online?
Thanks
marksm_macomb
In ArcGIS Pro, ArcGIS Online, and Field Maps you are only able to select one option from a domain list. Survey123 is the only application currently that allows you to set up a "pick multiple" question. The result that's written to the attribute will be a comma separated list of each option the user chooses.
GISUSER8
Thanks a lot
