Field Order Forgotten When Published to ArcGIS Online
3703
06-09-2015 04:27 PM
TylerBlack
New Contributor II
After I published a feature service to ArcGIS Online and moved it into a web map I noticed my field order had been reset.  In ArcGIS Desktop I arranged the fields to match the format of ArcPad which our field crew utilizes and to keep the layout familiar in Collector.  Due to the number of fields and layers, it would be time intensive to re-arrange all my fields again using the "configure attributes" window within ArcGIS Online.  Is there some other way to organize my fields in a web map?
Thanks
JeffJacobson
Occasional Contributor III
You can manually edit the JSON configuration files for items published on ArcGIS Online using ArcGIS Online Assistant.
JeffJacobson
ShanaHarmsen
New Contributor II
is there a way to do this not associated with ArcGIS online?  I have the same issue when I publish to ArcServer for use of feature service internally...
