Field contains multiple values separated by comma, want to list each on own line in popup.
3976
04-22-2024 12:16 PM
AriLukas
Hello all,
I have a Survey123 form that has a question that allows multiple answers. When the survey is submitted the field (Hazards) where the answers are input shows each value, separated by a comma (see screenshot below). For example some of the possible answers are Roof_Open, Holes_in_floor, Hazardous_Material.
I would like the popup to display each of the answers on a new line so instead of being a list separated by commas, as shown above, it would appears as:        Hazards: Roof_Open
        Holes_in_floor
I have tried creating an Array and then concatenating with the TexFormatting.NewLine but have not had any luck.
Any insight would be greatly appreciated!
jcarlson
Building on @SteveCole , once you have an array of items, use the function Concatenate to turn the array into a single string. This avoids having an extra line break at the end.
return Concatenate(
  Split($feature['hazards'], ','),
  '\n'
Then again, if your items are broken up by commas, you could just use Replace.
return Replace($feature['hazards'], ',', '\n')
You could also use Replace to swap the underscores for spaces.
var spaced = Replace($feature['hazards'], '_', ' ')
return Replace(spaced, ',', '\n')
- Josh Carlson
Kendall County GIS
SteveCole
Honored Contributor
Easy to do with Arcade. Instead of showing your Hazards field in the popup, you would should an Arcade expression instead:
var theList = Split("dog,chair,pony,table,sunshine,rainbow",',');
var theOutput;
for(var index in theList) {
  theOutput = theOutput + theList[index] + '\n';
return Trim(theOutput);
In my code sample, you would change out my comma delineated text string with a reference to whatever field in your data that has that list (e.g. $feature.Hazards).
jcarlson
return Concatenate(
  '\n'
- Josh Carlson
Kendall County GIS
AriLukas
Thank you @jcarlson  and @SteveCole  for both of your replies. I had to slightly tweak the above code but I got it to work. I probably should have mentioned I am working in Classic viewer, the below code is what I got to work.
var spacedHazards = Replace($feature.hazards, '_', ' ')
return Replace(spacedHazards, ',', '\n')
Thank you both again!
