Features with max. value don't appear in Web Mapping Application but in Web Map
1189
08-14-2012 07:39 AM
YannickTylle
I created a Web Map
http://we.maps.arcgis.com/home/webmap/viewer.html?webmap=fce12037605745a9a60706e94011f6b1
with Feature Services showing values in graduated colors. Everything looks fine in the Web Map so I shared it as a Web Mapping Application:
http://we.maps.arcgis.com/apps/OnePane/basicviewer/index.html?appid=609c46b0ccff48c384cab17958ab5c51
Here suddenly the features with the maximum value for the graduated color range (e.g. 95%) are not shown anymore.
How comes?
Best regards,
Yannick
BillMedeiros
I've run into the same problem.  I can create a map and edit the ranges in the legend.  The polygon colors render fine in the web map, but when I share it as a web map application using a template, one polygon shows up blank.  I can click on the blank polygon and the pop-up has all the correct information, just no color.
Anyone have any ideas?
GrantRussell
This is currently a known issue and has been logged as NIM084099.
