Feature Service- required fields
9807
11
04-19-2013 04:54 AM
AaronWorthley1
Is it possible to make some attribute fields in a hosted feature service required?  Ideally I'd like to make this change to an already published service.
MikeMinami
Esri Notable Contributor
Rickey Fite
You can add a "required" field by unchecking the "allows null values" option when creating the field. This option is available when there's no features in the layer. We don't show this option on layers with features because all records would violate the rule once the field gets created.
thanks,
Mike
AndresCastillo
I was able to resolve this in Web Appbuilder, using the Smart Editor Widget:
How to use Smart Editor to require user to populate field?
