Feature Layer View extent in AGOL doesn't match ArcGIS Pro
864
09-30-2024 09:19 AM
Labels (2)
LindsayDupont
I have a feature service published to AGOL and I have several feature layer views that filter to a specific location. I've used both a field filter and an 'area of interest' filter when creating the views.
When the view is first created, the extent of the view matches the parent feature service. I have gone into the 'visualization' tab and saved the desired extent, which is only the features in the view layer. In AGO assistant, the item's JSON shows the initial state has been updated and is correct.
When I open the view layer in an AGOL map, it loads as I like. However, when I add this view layer to a map in ArcGIS Pro via the Catalog Portal and 'zoom to layer,' it takes me to the extent of the parent feature service. The map is set to 'use extent of data in all layers.'
Any solution suggestions for this? Thank you!
