After the update on Thursday, one of our feature layers is no longer providing its table on the data page. The page remains blank, though it does say the layer is being updated when data is provided to it through a Web App. Our views based on this layer are also functioning, but we need this layer to power a task that provides the gathered data to another website. Since the table has become "unviewable", the task we are running cannot extract the data. We're currently at a loss on what to do and it is leaving one of our applications dead in the water for our business.
I just wanted to drop a Kudo to try and get this some more visibility and say that I'm experiencing the same thing. I checked the console and it shows the following error, "Uncaught (in promise) TypeError: Cannot read properties of null (reading 'layerType')"
There are a bunch of issues being reported here in the Community related to the June 2026 update. If it's possible, can you create a support ticket and then follow up here? I'm thinking it's probably important to get these things officially logged in their system for them to actually take action, and then other users who report the same issue can be tied to the bug report.
Hi @MayaZelaya & @JeremyBrown4 ,
Sorry to hear that you're experiencing an issue. A couple questions:
- Does the table still display in Map Viewer or the Visualization tab when you look at the data?
- How were these services created? Anything special? Just publish from a file, etc.?
- Do these services have item data saved to them? If yes, does the item data include references to all the layers and tables in the service in the response?
Regardless, I would suggest opening a support case so we can take a closer look and try to address this for you in a timely manner.
Taylor
I have placed a request in as well that references this post.
Just wanted to send an update on this in case it helps anyone else reading this post. When I opened the Visualization tab for the layer in question, the save option immediately showed a blue dot as if changes had been made. I went ahead and saved from the Visualization tab and the layer is function normally now.
