Feature Layer (hosted, view) - Editing is disabled
863
08-29-2021 10:58 PM
LuthfiAnggaraAtmaguita
Hi, previously I created survey123 and related table. It was successfully worked! After that I joined my layer and survey and had Feature Layer (Hosted, View) in result. After that I intended to make a webmap that can be accessed offline.
Although I have changed Feature Layer (Hosted) setting to enable sync, I couldn't do the same setting to the Feature Layer (Hosted, View). Why is that?
Feature Layer
My joined-layers result
David_Brooks
MVP Regular Contributor
It's just a view of the original layer, so isnt the sync setting honoured by the view layer and does sync actually work for you in survey123?
David
..Maps with no limits..
