feature layer failed to support arcade label
1490
12-27-2023 10:04 AM
hoogw
arcade label is not supported in arcgis online? It should, but it shows mess up code instead
https://palmspringsca.maps.arcgis.com/home/item.html?id=93756247f383480b9fe5cb890390e7c3#visualize
arcade label work fine in arcpro,
hoogw
6 years ago, 2018, this person had same issue as above.  6 years passed, ESRI still don't fix this problem?
https://community.esri.com/t5/arcgis-online-questions/confused-about-arcade-labeling-compatibility/t...
hoogw
I removed arcade tag, it works fine in arcgis online
https://palmspringsca.maps.arcgis.com/home/item.html?id=93756247f383480b9fe5cb890390e7c3&view=table&...
