Failed to save map Missing value for required property: numThumbs.
2682
02-14-2022 04:34 PM
Labels (2)
CoryBlackEagle1
I just recently starting getting an error when I try to save the map in ArcGIS Online new map viewer:
Failed to save map
At first, by rearranging layers and moving any time-enabled layers to the bottom of the list, I could get past it.  However, that is not working.
I recreate the same map in classic map viewer and it saves with no problem.
Anybody run into this and have a solution?  If not, I am going back to the classic map viewer, especially for my students doing their labs.
RussRoberts
Esri Notable Contributor
What type of layers are you using in the map? Is it a new map you are creating in the Map Viewer or updating an existing on? If you can, can you share the layers you are using to create the map?
AlainaRussky
I was having the same "numThumbs" problem.
Triple check that all your map layers are not time-enabled. I just checked all (20) layers in my map and found one that was time-enabled. I turned that one off and everything saves perfectly.
