Extent reset problem
2720
12-04-2012 03:32 AM
JamesCucinelli
I am working with ArcGIS Online for Organizations and making a mapstory.
My problem is that I go to set my initial extent
left -132 right -60
top 60 bottom 15
Then it saves it.
But then if I open the map in arcgis.com it's hit or miss whether it uses that initial extent.
Then if I have to make a change to a popup and save it, a new initial extent is set so I have to go back and reset my initial extent in the details web page.
Anyone else noticed this type of behavior and is there a way around it? It's very frustrating to have to reset my desired initial extent each time I make a change to the web map.
Thank you in advance,
James Cucinelli
JasonBalmut
Yes, this issue hasn't been corrected yet.  Link to the previous post.
JamesCucinelli
Any idea on when the initial extent problems will be fixed?
I'm creating more web maps and I enter the same extent parameters and I get different results on different maps.
JamesCucinelli
Any idea on when this will be fixed?
I'm still having the same problems.
James Cucinelli
