exporting layer views
4276
11
02-28-2018 10:46 AM
Mary_GermanWhitley
I have created a View Layer from a Hosted Feature Layer which contains only the fields/filtered data I am interested in via the Visualizations tab. The data tab correctly shows the filtered subset of fields. I would then like to be able to export only those fields/rows in the View Layer as a csv. When I do an export on the View Layer, it exports the entire dataset from the Hosted Feature Layer.  If I wanted that I would just export from the original. Am I missing something or is this a bug? (Create hosted feature layer views). Thx.
KellyGerrow
Esri Alum
Were you able to get to the bottom of this issue? If so, can you post the solution?
IF not, getting in touch with technical support would be my recommendation to see what is happening with your dataset.
Mary_GermanWhitley
No, I am still having the same issue. The rows export correctly, but I still get all the fields.
