Export to File Geodatabase does not work
9150
12
04-19-2022 05:55 AM
DaveBodak
I have several large feature layers (about 5,000 parcels in each) with attachments and related tables in some, but not all. I have realized that it has gotten the the point where I can't export my data as a File Geodatabase anymore in AGOL. It will just show a loading screen and default back to the screen with the original selection (shown below) and does not create anything from this data.
I have done some research and noticed this was a problem in 2018, I was hoping it would be solved by now and that I was experiencing a different issue. As we continue to locate more assets without having backup files saved in AGOL, there comes a bigger risk with losing significant amounts of data if something were to happen.
Here is that article I found: https://support.esri.com/en/technical-article/000015786
The only issue with this method is that it does not preserve everything within the feature layer and is more time consuming to go through.
Thanks for your help!
Tags (3)
DaveBodak
Thank you for the recommendation, I will try the method of just letting it sit for a while to see what happens. In the meantime, I will try the feature class to feature class method in AGIS Pro. Thanks!
DougBrowning
It is not just you I get this all the time for the last few years now.  Anything over 10 GB and it starts to not work a lot.  I usually have to create a replica instead at that point.
SarahRijneke
Are there any downsides to creating a replica?
I am trying to download a few feature services from AGOL to a stand alone gdb. The services are point layers of survey results with photo attachments. They consume quite a few credits and contain old data so I would like to take them offline and put them in an archived database. I don't know too much about replicas. Is the replica the same size as the feature service? Can/should I delete it once I've downloaded it? I have no use for it other than to download my data.
I've tried bringing the feature into ArcPro and exporting/importing it into the gdb. It runs all day and when I log on the next day I can see that the program has crashed. Sometimes it results in a new, empty feature class in the gdb. I have tried to append the dataset into the new feature class with similar results. Nothing has been moved over and ArcPro has crashed.
I have to do this for 3 features services, all with 5000+ records. Are there any other suggestions for moving it to an offline geodatabase?
