Export to feature collection not working
1007
04-29-2025 12:38 PM
JenniferFabian
I have tried to export multiple different hosted feature layers thinking maybe it was an issue with the one i needed. but non of them are working i get this error every time. Now if i chose to Generalize features for web display. it will work but non of my symbology is showing up at all.
PeterHodkinson
Hi @JenniferFabian are these layers particularly large or have complex geometry? Do you see the same issue if you test with a simple test layer (with just a few point features for example)?
David_McRitchie
Hey Jennifer, I just tried exporting a Feature Layer Collection I have and this worked, so it sounds like this could be data or service specific.
If you open the dev console on your browser (Press f12) and look at the network tab while exporting do we see any requests that fail, or provide a more detailed error within the Response subtab?
Hopefully we do, otherwise it is worth testing with other datasets to see if we can identify what is causing this.
David
Esri UK -Technical Support Analyst
