Export to CSV from ArcGIS Online
5490
01-27-2015 02:15 PM
GeoffreyWest
I have added a feature service to my content, however the edit properties fields do not appear where I am able to select if users are able to export the data.  What could be the issue? I am following this documentation.
http://doc.arcgis.com/en/arcgis-online/share-maps/use-hosted-layers.htm#GUID-074D6BFF-60C4-43B6-822F...
As the organization administrator I add a feature service ---> edit ---> properties, there are no properties available to export individual layers.
DanielStauning
Hi Geoffrey,
The key concept in the document you referenced is "Working with Hosted Layers." Hosted meaning published to ArcGIS Online. If you just added an ArcGIS Server service as an item to your to your content, This won't give you the ability to modify editing permissions or export data from the item description page, you need a hosted web layer for those capabilities:
About hosted web layers—ArcGIS Online Help | ArcGIS
-Thanks,
-Dan
DanielStauning
Hi Geoffrey,
-Thanks,
-Dan
