Export Hosted Feature Layer from AGOL using Python
1952
07-22-2021 01:47 PM
GIS_MJ
Hello. I use the following script to batch export and backup my Hosted Feature Layers on AGOL:
https://support.esri.com/en/technical-article/000022524
The script works great for most things. The problem I am running into is Hosted Feature Layers with an associated Scene Layer (multipatch feature published from PRO). The script, as is, creates a blank geodatabase for each feature layer that has a scene layer (i.e. no data inside the gdb).
If I change the query item type to Scene Service, Python recognizes that I have 8 items, but an error occurs on the download. If I change the item type to Scene Layer, Python doesn't recognize any items.
I would like an exported database with the multipatch feature just like the other features layers. I've tried writing the scene exports to SLPK, GeoJSON, and File Geodatabase. I am using Jupyter Notebooks to run the script if that matters.
Any ideas?
