Experience Builder /Survey Widget - Edit/Select Existing Records of Data with the same XY
986
11-21-2022 08:38 AM
JessicaJThompson
Hello All!
I am working with Experience Builder and the Survey Widget to edit existing records - making a current assessment of already existing data.
Everything is working well until I come to records that have the same XY.
I have added a pop-up for the data so that in theory you can select the different records, but the survey doesn't change from the "top" record even when the others are selected.
Is there a way to remedy this? I am relatively new to configuring Experience Builder, so any help would be great!
Cheers,
Jessica
