Experience Builder: Failed to construct 'IntersectionObserver': member root is not of type Element.
2950
04-07-2022 05:18 AM
Labels (2)
AlfonsoDodero
Hello everybody,
suddenly, without any modification to the configuration or to the web map, my experience no longer works correctly.
When I try to open the URL a page comes out with:
The application is public, so if you want you can see it yourself. Here the link:
https://experience.arcgis.com/experience/214ec116c6a44b9897f7883652be6b37/
The same error appears when I try to edit from the experience builder.
The environment I use is the normal ArcGIS Online environment.
If I create a new experience, the error does NOT occur. If, on the other hand, I create a new experience from the existing one (the one with the issue) it will present itself.
Hope you can help me,
thank you!
Tags (1)
craragon77
Yo I have this exact same issue to. I'm building a testing framework for a react.js-based program using arcgis/core. Did you find a solution to this yet? I am not having any luck
Tulasiram7
I am also facing the same issue, cannot able to figure it out, will get back to you if I found any solution.
CWCalkins
Has anyone found a solution to this? I am having this issue with my Experience, but it is only an issue for medium screen devices. The large and small screen device versions of the Experience are working fine. Any help would be appreciated!
