Error with Dates when Adding Features with Python API
836
02-27-2025 10:41 AM
mpboyle
I'm getting the errors shown in the first screenshot below when trying to add features to a hosted feature layer using the Python API.
The features throwing the error all seem to have dates at or prior to 1/1/1900.
When constructing the JSON for the features to add, I'm assigning our local time zone to the datetime object.  Is there a different approach I should be taking to avoid these errors?  The second screenshot shows a sample of the dictionary key and value being used when trying to add features.
If I set any dates at or prior to the year 1900 to NoneType objects, the features are written to the hosted feature layer without errors.
'DateField': datetime.datetime(1900, 1, 1, 12, 0, tzinfo=tzlocal())
CodyPatterson
MVP Regular Contributor
Hey @mpboyle
Could try this function here to just return any date earlier than 1/1/1900 to None, as that's the normal null value in a DB for date columns:
from datetime import datetime
def safe_datetime(date):
    return date if date >= datetime(1900, 1, 1) else None
'DateField': safe_datetime(datetime(1899, 12, 31))
In this case DateField will be None.
I think just setting to None will be one of the best bets here.
Cody
mpboyle
I'm already handling the dates if they're prior to 1900 (code below).  I'm really wondering why I'm getting an error at all when trying to insert a feature with a date prior to 1900...are these dates not supported by the Python API?
def format_date(input_value):
    if isinstance(input_value, datetime.datetime):
        if input_value.year <= 1900:
            return None
        else:
            return input_value
    else:
        return None
JohnEvans6
Came across this looking for something else doing something similar. I don't know if something that says "works on my machine" is helpful but everything seemed to upload for me doing the following:
Maybe there's something up with tzlocal() not producing a timezone object?
