Error inspector
269
09-06-2025 12:32 PM
GarryPetrie
Having problems following the instructions in the "Help" manual.
Specifically, the sentence below makes no sense:
"In the Contents pane, right-click the layer and click Add Error Layers "
in the help page
pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/manage-attribute-rule-errors dot htm
I never see the option "Add Error Layers"
Furthermore,
Once the Manage Error table is open, in only says, "Select a Map" A totally useless advise.
PS, I love how help can manage a URL within the help system.
HusseinNasser2
Hey Garry, I'm going to assume you are trying to evaluate attribute rules.
So first make sure you have batch calculation or validation rules on the class you want to evaluate. then add that class to a new map, and then right click on the layer on the map, you should see a new context menu AddErrorLayers, if you don't or it is disabled this means you don't have batch rules.
