ERROR 001270: Consolidating the data failed
1617
02-19-2014 01:14 PM
PaulKamis
I am attempting to publish a mxd that contains two tables, one of which is joined to the other based on a common attribute.  I then made an XY Event Layer off the joined table and symbolized that XY Event Layer.  All my data is housed in an enterprise geodatabase (postgresql) and was brought into the map document using database connections.  The database has been registerd with the server, and we have followed Every suggestion found at the help documentation at http://resources.arcgis.com/en/help/main/10.1/index.html#//00vp0000002r001270 to no avail.
Can anyone advise on what might be continually causing this?
Can you publish a XY Event Layer based off table joins?  Could that be our issue?
Thanks.
