Enabling Sync or Keep track of created and updated features prevents hosted feature layer save
1144
01-18-2021 02:03 PM
BillHeigh
Hi guys and gals,
I am attempting to publish an editable app in Field Maps and am having trouble. Currently the main issue is that as soon as I check the Enable Sync checkbox, the layer fails to save. I get this in the upper right-hand corner:
And I have tried and tried but to no avail. As soon as I uncheck which ever one prevented me from saving, I can save (other settings) again. I have tried rebuilding indices and creating a new web map from the hosted Feature Layer, no joy.
Help!  = )  Thanks, Bill~
BillHeigh
I think I solved my own issue. I have been migrating my inspection app efforts this month and I started with Collector in 2017. With each iteration, there have been changes and improvements and this effort was no different.
I had several schema changes since publishing to AGOL, and eventually I think you reach a point in the AGOL environment where there have been too many changes to continue updating layers designed for editing and you have to start over.
And that's what I did. I downloaded everything worth keeping from AGOL and deleted everything on AGOL having to do with that app and/or fixing that app. I started over with Desktop (I have been trying Pro the last few months, but it's a learning curve). I created the FGDB I wanted, and started a new MXD and published my inspection map again. Everything started working as expected again.
Cheers, Bill~
