Embedding an app on Website
1518
06-03-2024 02:05 PM
PhaedraDouglass
Hi everyone,
I am trying to embed an app on a website to share it publically, when I do so (following the instructions from the arcGIS webpage), it comes up with a login window on the website I am trying to embed on. What am I missing here?
I have successfully embedded a web map onto the same website and never had any issues. I have triple-checked all the sharing levels on all layers so it can't be that.
Any advice?
YuriWorkTech
Sharing on all layers AND the webmap itself need to be public.
GlenShepherd
Are any of the layers in your web map(s) coming from another server? (i.e. added via URL?)
If there are secured services present that haven't been added with stored credentials then you'll need to fix this... i.e. Content > New Item > add via URL > store credentials > then add the service back to your web map(s)
KimKorton
@PhaedraDouglass wrote:
Hi everyone,
Any advice?
I’m also encountering this issue right now! I’ve been trying to embed an app on my website using the same ArcGIS instructions, but I keep getting the login prompt as well. Like you, I’ve double-checked the sharing settings for all layers and made sure everything is set to “public,” yet the problem persists.
Have you tried publishing the app with different sharing settings or using a different embed method? I’ve been wondering if it might have something to do with specific permissions on the app itself, rather than the layers. If you find a solution, please share it—I’ll do the same if I figure anything out!
KimKorton
Hi everyone,
Any advice?
