Embedding a map or creating a public link
1049
08-07-2023 05:11 PM
Michael_TylerMcDaniel
Is there a way to embed or make a public link without a password? I tried opening it in classic viewer and it alters the map shading.
SaraJL
Embedding is not available in the new viewer yet (I asked tech support, and then said only in the classic viewer) so usually I add it to the Basic template in the Instant Apps and then there is an embed option. That should be a workaround for the symbology changes.
I noticed that it does that as well - if you switch to Classic Viewer, sometimes the colors and zoom/scale gets a little weird.
For the password part - that can be changed in either viewer! That's in the share settings - you have to mark it Public in order to not have a log in. If you mark is "organization only" then it will still require a log in.
Good luck with your project!
